Hello My suggestions; --Analysis settings-load-security-ts498 ex. load decrease. I applied it but the situation did not change, --S1 and S8 columns have a little extra reinforcement on the ground floor ceiling (within the limit values) other floors are normal. If you want to reduce the amount of reinforcement, you need to add curtains, --A1 and B1 irregularities do not matter since the dynamic calculation is made, --K9 beam is not fully seated on the walls, otherwise it may break in an earthquake, --Dissolve the ladder together, --If the attic will not be used, load the wall loads and You can reduce live loads. Unver ÖZCAN
