Reinforced project drawing..
evanes07
Have a nice day; I will add an elevator shaft in a ready-made reinforced project, I took the photos with my phone and I was able to upload the file from tc because it is high mb. There are 3 reinforced beams in the project, as in the photo, and in the description, it is also called 2 CRF cross walls. There are 3 columns that I have seen for the first time, like reinforced with iron, I have no idea how to draw them in ide 7, can you help?
Well, would it be possible if I showed this kind of steel sheathed beams and columns by reinforcing their reinforcement? And what I really want to ask is; This project was strengthened in 2011, now it is only desired to add an elevator shaft to the building with 5 cm dilatation. Is it mandatory to model with the building?
"evanes07":796cpfqp" said:
Well, would it be possible to show this kind of steel sheathed beams and columns by reinforcing their reinforcement? What I really want to ask is that this project was strengthened in 2011, now it is only desired to add an elevator shaft to the building with 5 cm dilatation.. .Wouldn't it be enough just to draw the statics of the elevator?Is it obligatory to model it together with the building?
If the elevator shaft you want to add is dilated 5 cm from anywhere and has no connection to the existing building, you can model it separately.
