Thank you. How should I go about making reinforced concrete? How can the ratio be supported? Also, due to the difference in the plan (the ones marked in red), the geometry problem cannot be solved. What would you recommend for it to be reinforced concrete? (Note: the part taken into the big frame part will be vault only)
