Hello there; You have loaded your project with the default values of old versions. Therefore, although there are no elements on your roof beams, the wall load was 325 kg/m^2, changed to 0. You did not pay attention to the units in the coating loads. There was a snow load of 150000 kg/m^2 and a unit weight of 200 kg/m^2. In Imo's documents, the coating unit weights vary according to the material, but vary between 5 -30 kg/m^2. Snow loads are given as kN/m^2 in the tables in TS 498. Pay attention to the units during data entry. It is normal for the steel sections to be insufficient with the above-mentioned load values. These situations were rationalized as a unit. However, find the most accurate loads from the specified documents and correct the data entry. The analysis settings were completely suitable for reinforced concrete. Activated combining element-specific mod contributions for seismic loads, ductility level high but R=5 visible, changed to R=7 Wide spans were passed with purlins, and double tension rods were used for support. At the same time, the lovers were one piece, divided by all intersections. There is still an inadequacy in your lovers, especially due to deflection. You will need to enlarge the section. Currently, reinforced concrete and steel elements seem to be sufficient except for purlins in the analysis results. Analyze and check the results after intervening the lovers. Good work.
