Hello, 1-My first question is, I get the error that the number of mods is insufficient. I do not get this error when the number of mods is 70. Do you mind if I interfere with the number of mods that much? 2-The building will be prepared as an attic on the ground floor. In the attic floor, they want to raise the walls by 170 cm and place the roof on these walls. The roof has a cradle and the wall in the middle is 400 cm. I removed the columns in the outermost contour to 170 cm on the attic floor and 25/30 I connected it with a beam. I know that masonry on reinforced concrete is not healthy, there is no such opportunity in the program. If I did such a thing, would I have done a healthier job than a masonry structure on reinforced concrete, whose behavior I could not foresee? I am not sure, I will prepare such a project for the first time, if anyone has a different suggestion I can apply it too. I am attaching the project. Thank you for your help and interest
		Log in or register now.
