reinforced concrete roof
serpilakbas
Hello, I am having a problem with drawing reinforced concrete roofs in buildings with a roof piece. It is often not possible to continue the columns, I cannot create beams and floors. That's why I avoid concrete roofs. When I have to draw, I calculate 1x more and lay manually. municipalities do not cause much trouble, but this does not make much sense to me. I will be glad if you can help me which method should I use.
If the reinforced concrete columns cannot be made most of the time, make the relevant parts of steel, transfer the support reactions of the steel system to the reinforced concrete system. You can also create it in a wooden roof system with light panel systems. There is also a masonry system, but I do not recommend it. G.KÖSE
If it were me, I would remove the columns like a normal floor column, then enter the upper elevations of the columns according to the roof slope and bring them to the design size. I will create inclined beams and lay inclined floors between them. So solving the problem like this either seemed simple to me or I could not understand your problem, maybe :)
I do as you say in projects that don't have a floor play. But when there is a chiffon it is not possible to continue the columns.
