reinforced concrete column steel beam
ozgunerdogan41
Hello, these days I use idecad more intensively compared to other programs. That's why I may have some questions about modeling etc. I think you will excuse me about this. My point is that I want to use a kind of gusset joint when throwing steel beams on a reinforced concrete column, for this purpose it is anchored into the reinforced concrete column. I did not know which connection macro is idecadde (I could not see an anchor in the joint I assigned) or if there is a suitable equivalent macro in idecad. Thank you. Sent from my SM-N950F using Tapatalk
Hello there; You can use butt plate joints. However, when these connections are attached to the reinforced concrete element, you will see the bolts on the 3D screen, but you will not be able to see the anchor points in the reinforced concrete drawings, you will have to intervene in the drawings.
