Reinforced Concrete Column-Steel Beam Joint
lookindoors
Hello, Is it possible to create an idecade combination that we use to prevent the plates from reaching their yield strength under loads caused by large shear forces in wide openings.
We cannot create this component with your macro with forehead plate and gusset. Best regards
Hello there; In the joint you have shared the image of, a special support joint for the plate group that supports the beam sub-header is not available in İdecad Çelik 8. However, if you share more details about the usage areas of this combination and to understand all the auxiliary elements from different projects from different angles, new combination studies are being carried out. In this process, this combination can be evaluated for inclusion in the program. Good work.
Selamunaleyküm friends, I threw a steel beam on a reinforced concrete column. How should I combine? I will be glad if you help. I uploaded the project.
Hello
"erşahinler":2b72gaa1" said:
hi guys, I threw a steel steel beam on a reinforced concrete column. How should I make a joint. I would appreciate your help. I have uploaded the project.
My Suggestion You can do as in the links given in the attachment. /www.idecadsupport.com/forum/viewtopic.php?f=27&t=7526#p32102]viewtopic.php?f=27&t=7526#p32102[/url]
Ünver ÖZCAN
