Hello there; It is an error in the current version that the bolts cannot be formed on the screen in the butt gusset and gusset combinations defined between the reinforced concrete column and steel beam. The situation in which it occurs is reinforced concrete column width >=reinforced concrete column height. For example, while bolts are being formed for a reinforced concrete column with dimensions of 70*90; Bolts cannot be created for 90*90. Fixing the error is unfortunately not possible in this version. Good work.
