Reinforced concrete column, steel beam combination
smsenturk
Hello, I wanted to attach a steel beam to a reinforced concrete column. I tried to do this from guse join but I couldn't. Where am I going wrong? Thank you so much in advance...
Hello there; Guse Joint is a joint formed for steel column - steel beam, the proper geometry was obtained in the reinforced concrete column - steel beam, but this version has problems with the bolts of the joint. For this reason, you cannot create the combination exactly as you want on the perspective screen. You have to define the joint in this way and manually arrange the bolt placement in the drawings. The problem has been noted. Good work.
