Reinforced concrete 8.61 Insufficient slab or faulty slab axis
BURAK AKTÜRK
Hello, I shared the link above. When I check the geometry in my final project: I get the error "Insufficient flooring for DZ03 slab or faulty slab axis" on the ground floor. I could not find where it came from. What should I do when I encounter this error? On the last floor, I combined the console floors with eaves and made a single floor, but this time it gave the error that it does not provide the floor thickness, what should I do, naturally I do not want to choose more than 15 thicknesses. Thank you very much in advance.
Re: Reinforced Concrete 8.61 Insufficient flooring or faulty flooring Hello My suggestions; --For DZ03 tile: Since tile pieces remain, select all tiles from the select all icon and delete them and create them again, --When the calculation is made, there is insufficient curtain and tile, (7 errors) Ünver ÖZCAN
Re: Reinforced Concrete 8.61 Insufficient slab or faulty slab
"unver":39fn1i32" said:
Hi My Suggestions; --For DZ03 slab: because there are slabs left, select all tiles from the select all icon and create again, --When the calculation is made, the curtain and flooring are insufficient. (7 mistakes) Ünver ÖZCAN
First of all, thank you very much for your interest, Mr. Ünver. After deleting all the tiles and redefining them, I prevented that mistake as you predicted. The curtain error you mentioned is the program 380 for the height of the ground floor. Although it looks like cm, it is 280 cm. So, due to the working logic of the program, I get the error "curtain height cannot be less than 1/15 of the floor height", if you find it right. I couldn't get an answer to my second question, so what should I do to make the console floors on the top floor error-free? would you recommend me to do it?
"BURAK AKTÜRK":1uneym5h" said:
Unver, thank you very much for your attention. I deleted all the floors and redefined that error as you predicted. The screen error you mention is that the program sees the height of the ground floor as 380 cm, whereas the program sees it as 280 cm. That is, due to the working logic of the program, I get the error "curtain height cannot be less than 1/15th of the floor height", if you find it correct.
I couldn't get an answer to my second question, so what would you suggest I do to make the console floors on the top floor correct?
--What you need to do is increase the thickness .(Because the console is 2m.) Unver ÖZCAN
