How do I set the column stirrups, for example, where there is no condensation, the project does not give an error at 12, but I want to do it 17, this time it gives an as(-) error.
Hello, you did not write the column dimensions, Earthquake regulation figure 3.3. If you examine ü, if the short side is 25 cm in size in your columns, the middle zone stirrup spacing will be 12 cm.
