ottomancagatay
Good afternoon... I am a senior student at the European University of Lefke Dr.Hakan YALÇINER, I would like to receive information from you regarding the graduation project I received from my teacher. The subject of my final project is briefly and concisely, building reinforcement as a result of reinforcement corrosion. I have a few questions to ask, I would appreciate if you could explain in detail.
-For example, as a result of corrosion in a 50-year-old building, 14 gauge irons turned into 12 gauge irons, I modeled the building with its existing (ie 14 gauge iron) reinforcements, I entered the corrosion factor, what difference does it make if I don't enter the reinforcement factor I entered here, but directly enter the current iron diameter? -When I enter the corrosion of the reinforcement and do a linear analysis, in which part of the report can I observe the effects of the change due to this corrosion? I would appreciate it if you could explain the capacity diagram and the interaction diagram.
