I WANT TO MODEL A RAMP AS SHOWN IN THE ATTACHED PROJECT. WHEN I DEFINED IT AS A SINGLE FLOOR AND I SLANGED IT IN BOTH DIRECTIONS, THE MODEL I WANTED WAS NOT CREATED. I WOULD LOVE TO HELP. THANKS...
Hello. The ramp in your project cannot be modeled as a single slab. At the points where the exit direction changes, you need to divide the ramp with the beam or slab edge and incline each slab piece by giving the Slope ratio and the Start elevation with the "Bevel Objects" command in the Floor toolbar. The second method is to draw the ramp contour and exit line with the Route objects and create a ladder command. A ramp model can be created using You can find the model I created in this way in the attachment. The analysis takes a long time because Rapma is added to the analysis model.
In addition to Yasin Bey's warnings, if your mezzanine floor is going to be a hollow floor, there will be no problem if you take the double-sided and first direction to short beams. In my opinion, the sections are weak in such long beams.
Option2: If it is to be done using the ladder command, select /single arm /without landing/ Partially rotating stairs / Ladder6 type in Stair types From the Stair Settings / Construction tab / construction types / mark the ramp. Edit the dimensions a bit with the ladder deformation. Then determine the support conditions. You will have the chance to capture the model you want exactly.
