Raft Temel 0 additional reinforcements
ganymede
Additional reinforcements appear in the adjoining, un-amplified raft foundation, reinforced concrete dialog, but their number appears as 0. Not in the drawing, only in the concrete dialogue. Is this a problem? While this mat is laying the foundation in the program, the raft lays problematically as if there is a gap on the tile edge. I also deleted the reinforcement axles and threw them manually. Has anyone encountered such a situation? Respects.
"ganymede":pq0qsvnj" said:
Adjacent, un-ampled raft foundation, additional reinforcements appear in the reinforced concrete dialog, but their number is 0. Not in the drawing, only in the reinforced concrete dialog. Is this a problem? When laying this raft foundation in the program, there was a gap at the edge of the raft slab I also deleted the reinforcement axles and threw them manually. Has anyone encountered such a situation? Regards.
Hello Can you attach the project file?
When we wanted to delete the mat tile and redefine it in your project, we noticed that the borders were wrong. If you define the raft slab edges as in the attached project, the numbers will appear in the additions. In addition, there is a vertical continuity problem due to the curtains given upper level in your project (you can see it in the geometry control). In the attached project, this problem was resolved by arranging the element elevations.
I was getting the same error even though I deleted and redrawn the mat tile edge many times. Now when I try again, I get the same result. Unfortunately, I did not understand what I should pay attention to. But thank you for correcting it. Also, you locked the curtains and made them invisible in basic mode. How can I make it clickable? I looked at the layer settings, it has not been tampered with from here. Do you have another method?
The difference between the nodal points of your sub-basement curtains and your column nodal points has caused small deviations between your curtains and columns. Due to these eccentricities, some of your elements stay outside the raft slab edges. If you pay attention to such situations, you will not encounter such problems. In the project I sent before, the curtains not appearing in architectural mode do not occur to me. But it may be related to the drawing order. Select your foundation and right-click on it. When you click on the drawing order and send to the background from the drop-down menu, the situation you mentioned can be corrected.
I noticed it when I zoomed in quite a bit. The problem of not being seen was also solved as you said. Thank you very much. Don't be missing.
