"gencideci":cngakeo3" said:
			I am building a 4-storey building. I added the raft tile last and it gave an insufficient section error. I deleted all floors, I left only the basement floor, it still gives a meaningless section error. I don't understand the problem? Is there anyone who can help? The project is attached...
 Hello, the warning on the raft slab, the minimum thickness control warning. In the program, the distance between the columns is checked for the clear span value (Ln). With the "Reinforced Concrete Calculation Axis Edit" command, you can interfere with the value of the reinforcement axles -clear clearance for thickness control. Good work
