First, do I understand the following feature of the program correctly?: Analysis system display options / Shell Results / Raft Basic Results / Ace -1 Top, Bottom, View Side or Ace -2 Top, Bottom, View Color according to the loading status when examining the sides It shows the results in cm2 / m as the range. If the values written here are not 0.00 cm2/m, it states that I need reinforcement in that area. In raft flooring, the program calculates and determines the required reinforcement (and additional reinforcement if necessary). There is no problem in the Reinforced Concrete dialog and Account reports. However, Analysis system display options / Shell Results / Raft Basic Results / As -1 Top, Bottom, Visible Side or Ace -2 Top, Bottom, Visible Sides, while examining the loading status, as a color range of 0,00 cm2 / m There are bigger results than I want to ask: 1-What does it mean when there is no warning in the Reinforced Concrete dialog of the raft slab and in the Calculation reports, but results larger than 0.00 cm2/m in the Analysis system display options? Do I need to interfere with something as a user?
