Raft is basically a bug and I'm getting one B bug
tasyapı
HELLO, I want to solve the system semi-rigid and superstructure interactively. I want to define the raft foundation of my building 50 cm and the foundation of the car park ramp 30 cm. I don't get any error when I don't define 30cm foundation. but when I define and analyze 30cm baseline, I encounter 50cm raft base error and one B error. can you help me what should i do? Good luck with.
Re: Raft is basically running into error and one B error Hello My suggestions; --one. The walls between the A axis and 7' axis up to the S21 column on the basement floor and the S14, S15 columns outside are removed as they are not connected to the building, and --the raft foundation between the BF axis and the 7-7' axis together with the building raft foundation (as a single foundation) is more suitable. I think it will. --Retaining wall can be built instead of the deleted curtain if necessary. Unver ÖZCAN
Re: The raft is faulty in the foundation and it encounters one B error
"tasyapı":2cgfhtow" said:
HELLO, I want to solve the system semi-rigid and superstructure interactive. The raft foundation of my building is 50 cm and the foundation of the car park ram is 30 I want to define cm. I don't get any error when I don't define 30cm foundation. But when I define 30cm foundation and analyze, I encounter 50cm raft fundamental error and one B error. tc/server5/9jqugq/PROJE11.rar.html]http://s8.dosya.tc/server5/9jqugq/PROJE11.rar.html[/url]
Hi, -Analysis Settings/Basic-Base Tab " Evaluate the analysis option by ticking the "Enlarge the connection area" line for the raft foundation-superstructure interaction. -To solve the Joint Break Safety (B) problem in the S06 column, the short side of the column can be arranged as 35 cm. You can examine the 9th item in the frequently asked questions on the subject.
Good work
Re: Raft is basically a bug and encounters one B bug
My suggestions; --one. The walls between the A axis and 7' axis up to the S21 column on the basement floor and the S14, S15 columns outside are removed as they are not connected to the building, and --the raft foundation between the BF axis and the 7-7' axis together with the building raft foundation (as a single foundation) is more suitable. I think it will. --If necessary, a retaining wall can be built instead of the deleted curtain.
Ünver, thank you. I did as you said but I still get the same error.
Re: The raft is basically an error and it is encountering one B error Hello --From the reinforcement selection, mark the fi18 reinforcements on the basis of the raft and make the calculation. There is no problem. Make the --B mistakes as Levent says. Unver ÖZCAN
