Raft Fundamental Analysis Results
dündar selçuk
In the raft basic analysis results, the most unfavorable M11 and M22 moment effects and the combination of loading these effects are not reported. We can only view it on the screen in the shell results tab in the analysis design visualization section. Can we get these values as a report?
Your request has been included in our notes. At this stage, you can add the information in the Raft Reinforced Concrete dialog/Moment Reinforcement fields tab to the reports by taking a screenshot. Good work
Thank you very much for your interest, Mr. Levent. I understand your solution suggestion. But I think the effects displayed in this window in the reinforced concrete dialog are the effects that occur in the reinforced concrete calculation axis that we have created. These values may not be the most unfavorable effect in the entire raft plate. Is it true?
Also, moment values in the "Additional Reinforcements" tab in the Raft Reinforced Concrete dialog, "Moment and Reinforcement Areas" If it is greater than the torque values in the tab, would it be more appropriate to consider this value as more unfavorable?
"dundar selçuk":2w0c4dj5" said:
And in the Raft Reinforced Concrete dialog, the moment values in the "Additional Reinforcements" tab, "Moment and If the "Reinforcement Areas" is larger than the moment values in the tab, would it be more appropriate to accept this value as more unfavorable?
In the program, the main reinforcements in the beamless raft are determined according to the design moments where the calculation axis passes. If there is a large moment, additional reinforcement is thrown to meet this moment.This information is also given in the picture you attached and in the Raft Additional Accessories report.
