raft foundation
matrax
arthroma problem with less than raft foundation thickness, verlyo ground tension, in columns, beams. I have given an apartment, about 1.2m, but I know how we can make an application if such an application is not made, and do I need a 3 meter curtain in the basement, do not define the curtains as flooded curtains that do not continue.
"matrax":1txcnun0" said:
the raft foundation thickness is low, the problem is verlyo-floor tension, in columns, beams. I have given the apartment about 1.2m, but I know how we can do it if such an application will not be made, and do I need a 3 meter curtain in the basement? defining the basement as a non-continued curtain
Hello, We would help you if you could write your project more clearly, by adding your project and specifying the process step by step on the project. I did it like this, like this... If the basement curtains are located along the floor height, the relevant floor is rigid. You should consider it as a basement. If you define a rigid basement floor, it doesn't matter if you mark the aforementioned curtains as curtains that do not continue to the basement/upstairs. Sub-basement curtains are the ones entered in floors that do not have a rigid basement floor and that do not continue along the floor/structure height. Modelling of basement curtains:
Information about defining rigid basement: 13 .question...
