Raft Foundation
Mr. Kasky My suggestions for your project, 1- you fixed the reinforcements of the columns, you need to remove them. (fixing is required in the reinforcement project.) 2- when the column fixing is removed, your error number decreases. or rib thickness can be increased.) 4- B, M, Z, Br errors should be corrected in 5 beams, (their thickness can be increased.) 5- B, M, Z, As errors are present in columns, (column dimensions should be increased) 6- rib loads 0.5 tf/ m2 taken, (0.35 tf/m2 can be reduced, horizontal force will decrease) 7- your ground safety is around 14 t/m2. if the soil safety stress you entered is correct and you cannot increase the soil safety stress percentage; a- you need to improve the soil and increase the soil safety stress b- you need to make a piled raft foundation 8- there is a static error in the CURTAIN PROPOSAL I gave the image of. It would be better if you remodel. Take it easy Unver ÖZCAN
