Raft Foundation
kasky
At first, there were 6 basement floors with a height of 145 cm in the project, but then, by making changes, 6 . I deleted the basement and this floor is 5 . I added it to the basement, after this change, the raft foundation did not save what I did, how should I change it basically
"kasky":3sg5e8dx" said:
at first there were 6 basement floors with a height of 145 cm in the project, but then I deleted the 6th basement floor by making changes and added this floor to the 5th basement floor. i should change
Hi Settings --> Analysis Settings --> Foundation - Ground tab, activate the "Enlarge the connection area" option in the raft foundation superstructure connection options. This option allows the size of the rigid bars that connect the columns and curtains to the raft foundation proportionally to the height of the foundation. and will make the load distribution more suitable.You can eliminate the soil tension problem in this way.
