Raft Foundation Thickness Insufficient Warning
"miralay":t75236rq" said:
Why does a raft with no load other than its own weight give a thickness error when the foundation model is modelled?
Hello, the thickness condition to be complied with as per the regulation may not be met. The program uses the free opening used for thickness control. It is determined according to the position of the reinforced concrete calculation axis.You can see the free span value with the calculation axis edit command, you can also change the value if necessary.
