Hi, In the attached static project, the raft foundation maximum stress exceeds the average stress. How can I fix? I can't expand right side. Thank you from now. I wish you good work.
Mr. elifabus My suggestions: --Correct the errors in the geometry control, --Make a zero on the raft foundation with 4.5 t/m2 load, --Since the S17 column is given as a single bar, you cannot add beams to all floors in front of the elevator shaft, delete it, --Wear the beams on the curtains in the basement reduce the height by the beam height above it, -- Enter the stair loads, -- Put inclined beams in the mezzanine between S04 and S08 to support the ladder, -- Check the option Multiple Conjugate Winkler.... on mat foundations, -- If you can increase the ground safety stress by 50% it saves. SOME UNcorrected DATA IS ATTACHED Take it easy Ünver ÖZCAN
