It is not possible to define such a foundation in the program, but if you enter your foundation as 3 (or more) separate regions of the raft edge and adjust their heights at the relevant height, the program will automatically detect the slab continuity and perform an accurate static analysis. In the example I have attached the screenshot, I have given the thickness of the raft pieces as 40-60-80-100 cm from the inside to the outside, respectively. You can calculate the reinforced concrete of the continuous sections manually (with classical methods) based on the M11 and M22 moments in the relevant direction, or by defining the reinforcement axes along the continuous section and starting from the moment diagram along the reinforcement axis.
