Raft foundation reinforcement range
atillaaydın
Dear colleagues, in the project I have drawn, the raft base reinforcement range is 12-13. but the same project was drawn and applied with seta4 cad and the raft base reinforcement spacing is 14-15 cm, so I need to keep a maximum of 14 cm spacing in this project. I would appreciate it if you could help me with this. I am waiting for the help of you sensitive friends, thanks in advance. I'M TRYING TO ADD THE DATA OF THE PROJECT BUT I CAN'T LOAD IT BECAUSE THE FILE SIZE IS LARGE
Hello there; You can make the most economical and suitable solution if you change your purchase value to 0.00175 for the principal direction and the other direction defined for the raft foundation under the heading of reinforced concrete / parameters / raft flooring parameters. Also, I would not recommend you to take the example of the program you mentioned, because the pursantage values defined in the program you mentioned are too low to provide the regulation values. As a user, it should be intervened there and increased as I said. See TS500 Best Regards... Sent from my iPhone using Tapatalk
Thank you very much for the information you have provided. I changed the pursontaj value to 0.00175 for the main direction and the other direction as you said, but there was no change in the reinforcement range. Can you check my slab parameters? Is there something wrong?
"atillaaydın":2py616os" said:
thank you very much for the information you have given. I changed the pinning value to 0.00175 for the prime direction and the other direction as you said, but there was no change in the reinforcement range. /quote] Hi, you need to look at the "Raft tiling parameters" You have changed the "Tile parameters".
Sorry, I'm so sorry I changed the flooring parameters by mistake as you said. I will change the raft flooring parameter and get back to you after the analysis. THANK YOU SO MUCH FOR YOUR INTEREST.
