In my related project, I could not understand the reason why the base thickness was 100 cm but the miter length was 50 cm. If the base height is 80 or 120, it still does not change, it becomes 50 cm. I will be glad if you help me urgently
In the program, the square length of the raft reinforcement reinforcement is limited to 50 cm. If it is desired to be drawn larger, it should be intervened using 2b possibilities after obtaining the basic application plan.
