help everyone. The attached project is the z4/D group. I solve the superstructure interactively, I also use the multi-conjugate winker spring method on mat foundations, but I still can't recover the ground safety stress. I would appreciate your help.[/ quote] my esteemed colleague; the problem in your project is not only the main problem. You should also think about the design (if there is no architectural necessity, it can be thought more easily). However, if you want to take care of the foundation first, if you enter your curtains as a panel rather than a column and choose the calculation method accordingly, you will see that your foundation is quite relaxed. .With the completion of the column scheme and the frame in a healthy way, there will be no problems in the basics. Take it easy.
