raft foundation error
emrahkoyuncu
Friends, I have a project that I did not solve the problem in the attached file. I am constantly getting the error of lack of raft reinforcement in the project. I increased the thickness of the foundation, increased the width of the foundation, increased the diameters of the reinforcement, deleted the foundation and redefined it, checked the loads, checked the geometry, as a result, I could not correct the error. Could you please check my project? Can you tell me if there are any other problems?
Hello. The situation improves when the raft flooring reinforcements are made fi 18-20 from the reinforcement selection and the calculation is made. But; --There are curtains on both sides in the basement. Basement floor is considered rigid. If this acceptance is to be made, it is necessary to put a curtain on the opposite sides. --Enter the stair loads, --Reduce the live loads on the attic floor and remove the wall loads. --Connect columns S14-15-16 to form a frame. Unver ÖZCAN
