Raft Foundation Design
M. Sait Aksoy
Hello, dear friends, I have a problem with a project, I would be glad if you could help me. I have a container project. I'm designing a raft foundation. I can't analyze only the foundation of 11 m by 3 m. I think it gives the error "modol E1 mass not found". I think it does it because I do not define a load or structure on it.
Hello, For raft foundation analysis, at least one column or shear must be defined in the project. You can't just get the raft fundamental analysis and report. If you want to make raft analysis independent of the structure, you can define short columns at the points where you will enter external loads and moments, and define load and moment at the bottom ends of the column. If a column or curtain is defined in your project and a message occurs, please add your project.
