"Mbaki":jym98ksz" said:Hi, I have an architectural project of a light steel prefabricated structure, how can I do the raft foundation analysis? At least one column or shear wall must be defined in the project. If you want to make a raft analysis independent of the structure, you can define short columns and define the load and moment at the column ends. You can refer to the link below to define additional loads on load-bearing elements.You do not have permission to view link Log in or register now.Good work
You can define columns as short as the number of steel columns pressing on the foundation and define the loads and moments coming to each column.The most appropriate solution is to solve the steel structure and the foundation together."Mbaki":uzf9hs2w" said:thank you for your attention. I will define a total of 10 tons and 3 tons of live load for the structure. How accurate is my definition on a single column
