Burak Aydın
Hello, sorry the title is a bit short, my problem is that I am solving a building with 2 blocks, the relevant administration basically wants an elevator shaft (I don't have a problem so far), I have 2 different elevators in each block, but for these shafts, the curtains around the existing elevator are under the foundation -160 It wants it to start from the ground level, at the same time, whatever foundation type I use (100 cm raft), it also wants the same foundation for the floor of these elevator shafts. In the first block, I solved it by raising the curtains around the elevator shafts and opening a gap in the foundation, laying the raft again in the space I opened - adding jeans, I did not have any problems, but when I do the same for block b, there is no problem when I do it for the first elevator shaft, but 2. When I do it in the elevator shaft, the raft basically drops to my minimum ground tension and I get a shear force error on the curtains, I could not solve this problem. I would appreciate your help, respectfully (I am using idecad version 8.5), because the file size is large, I put a link
Log in or register now.
