Raft flooring thickness problem
civilman
My attached project is for trial purposes, and it was solved as a raft in another static program, and when I tried it, I couldn't save it with 170 cm. Is there a problem with my raft application or is there a place I don't know? The place is dilated and we cannot open the foundation, the upper part is the same with the solution of the other engineer friend. Thank you in advance for your help and experience, I wish you good work
Hello, In your project, the foundation does not relieve the safety stress of the ground. If you do an amputation, this stress will decrease.
the place is dilated and we can't open the foundation, the top side is the same with the solution of the other engineer friend.
I don't quite understand what you mean in this part. If you explain, we can help.
Good day, thank you for your reply. When I say we can't open the tile, I mean I can't expand the raft tile limit. I wonder how the ampatman will be done in adjacent raft flooring? I would appreciate it if you could give examples. I don't know because I haven't applied it before. Respects
"M. Berat Denli":1nmljafb" said:
Hello, In your project, the foundation does not relieve the soil from the safety stress. If you do ampathes, this stress will decrease.
the ground is dilated and we cannot open the foundation, the upper part is the same with the solution of another engineer friend. I don't fully understand what you mean in the section. If you explain, we can help.
Good day, thank you for your answer. When I said we can't open the tile, I meant that I can't expand the border of the raft tile. For I don't know. Regards
"civilman":ljcm5soy" said:
Good day, thank you for your reply. When I said we cannot open the tile, I meant that I cannot expand the border of the raft tile. quote] You can't get an amphitheatre in an adjacent arrangement. You can change your foundation system, try a pile foundation system. Another option is to request ground improvement.
I would like to get a comment from the Idecad Manager friends, I'm sorry if I say something absurd because I don't know.
"civilman":j1zsm1bt" said:
I would like to get a comment from Idecad Manager friends, sorry if I say something absurd because I don't know
Forum members with the ideCAD logo on their profile avatar are ideCAD employees.
