sadikcafer
Hello, I made a raft foundation in a 13-storey building, but I got a negative ground safety error. I have a few questions; 1-) I made a continuous foundation of 100cm(height)-100cm(width) around the foundation and placed a 100cm raft slab on the inside and since my floor class is Z3, I chose the superstructure interactive solution and had it analyzed. The building has made a huge deformation in one direction (it was officially overturning), it doesn't see the foundations all the time. 2-) In the perspective region, it shows the foundation displacement as 13.44mm in red and this happens under the elevator curtains in the core of the building, can I build a continuous foundation only on the underside of the curtains (by laying 100cm raft on the rest of the walls)? 3-) There is a 100cm thick raft floor in the picture and there are 1.50 protrusions from all over the building, still the same problem, the biggest displacement under the elevator curtains
