Hello, Raft additional reinforcements are analyzed As a result, it is determined automatically by the program where the main reinforcements do not meet the need. If the reason for this question is to apply as a single reinforcement instead of additional reinforcements in small areas, you can combine the reinforcement with the "Combine" command in the Additional reinforcements tab. Note: When the analysis is done again, the additional reinforcements will return to their previous state. Good work."legasov":6i07yjdk" said:Hello, can I add additional flat reinforcement to a region I have determined in raft flooring?![]()
Thanks for the answer, but the main purpose of my question was to get information about whether I can solve the stapling formed at the raft-column, raft-curtain, floor-column, floor-curtain junction points with only additional reinforcement without increasing the size. I would be happy if you can help."Levent Özpak":29949hmn" said:Hello, Raft additional reinforcements are automatically determined by the program where the main reinforcements do not meet the need as a result of the analysis. If the reason for this question is to apply it as a single reinforcement instead of additional reinforcements in small areas, you can combine the reinforcement with the "Combine" command in the Additional reinforcements tab. Note: Additional reinforcements revert to their previous state when reanalyzed. Good work"legasov":29949hmn" said:Hello, can I add straight reinforcement to a zone that I have defined in the raft slab?![]()
Additional reinforcements in the raft foundation are not punching reinforcements, but additional reinforcements that meet bending moments. If punching reinforcement is used to solve the punching problem, it is selected by the user from the Column-curtain properties/ "Punching reinforcements" tab. You can review the links below."legasov":1mtzzqee" said:Thanks for the answer, but the main purpose of my question was to get information on whether I can solve the stapling at the raft-column, raft-curtain, floor-column, floor-curtain junction points without increasing the size with just additional reinforcement. I would be happy if you could.
Well, would it be OK to use evenly spread kibble as a staple reinforcement on a 50 cm mat base? What is its applicability?"Levent Özpak":ynn9m6bn" said:Additional reinforcements in raft foundation are not punching reinforcements, but additional reinforcements that meet bending moments. The solution to the stapling problem is selected by the user from the Column-curtain properties/ "Punching rebars" tab, if stapling reinforcement is to be used. You can check the links below."legasov":ynn9m6bn" said:Thanks for the answer, but the main purpose of my question is to avoid stapling at raft-column, raft-curtain, slab-column, slab-curtain junction points without increasing size. it was just to get information about whether I could solve it with additional equipment. I would be happy if you could help me.You do not have permission to view link Log in or register now.You do not have permission to view link Log in or register now.Good work
"legasov":1qk51vqx" said:Well, would it be correct to use evenly spread crossties as a punching reinforcement on a 50 cm raft foundation? What is its applicability? How different punching reinforcements will meet punching stresses and their drawings are given in TBDY 2018 clause 7.11.10, clause 7.11.11, clause 7.11.12 and Figure 7.16.
