mhanifiata
1-no lock option for additional accessories. The main equipment has this feature. If you reduce the reinforcement spacing to 5-6 cm or choose a larger diameter for additional reinforcement, the problem is solved. or you can manually adjust the reinforcement. this setting has no effect on the analysis results. If there are additional reinforcements that are very close to each other, combining them provides convenience for the application. however, it can slightly increase the amount of reinforcement. As the 2-finite element width decreases, the model calculation becomes more precise. however, the analysis time becomes longer due to the larger model size. On the contrary, the larger the finite element width, the lower the model precision and the shorter the analysis time. generally 50-75 cm is a good element size. The biggest factor that determines the 3-raft thickness is the punching load and the net clearance. You can adjust the thickness by comparing the stapling load with the stapling capacity.
