Good afternoon, I would have questions about the project I was working on at a few points that I was stuck on. As seen in the photos, there is a 20 cm level difference between the area drawn with the yellow line and the large area. In order to make this level on the raft, I first created the RD1 raft. Then I created a space in the area related to the floor space and surrounded the area related to the raft floor edge and defined the RD2 raft with -20 cm elevation. Then I defined curtains for the parts where the stage is. I defined curtain elevation -20 cm with upper elevation -300 cm and combined it with the combine command in the curtain auxiliary toolbar. In the reinforced concrete tab, I marked the "model as shell line" and "flooded/non-continued curtain on all floors" lines. There are 3 columns at the intersection of the levels, and I get an incorrect intersection error in the geometry control at the section where these columns are located. And again, it looks like two RD1 and RD2 rafts are defined in the geometry control. 1-What are my mistakes in the explanation above and how can I create the stage on the raft? 2-How can I fix the errors in the reports section as a result of the analysis? Project download link
Log in or register now.
