Raft basically ace problem
ahmet_aydin
somehow I could not overcome the problem of reinforcement raft basically ace. I wonder where I am doing wrong, can you take a look?
şabanide_radye_temel_sorunu27_06-09_14.bak.html
Hello, since you cut the continuity and create a gap in the P19 curtain, the foundation stresses are excessive in that part. You can see the hard place in the additional reinforcement section of the raft foundation. You can increase the additional reinforcement area in that section, or you can save the foundation with less additional reinforcement area by dispersing the stress by placing a column at the end of the P19 curtain wall. The most reliable solution is to extend the P19 curtain up to the S06 column if it will not pose an architectural problem.
"M. Berat Denli":1n7yv5kv" said:
Hello, because you cut the continuity and create a gap in the P19 wall, the foundation stresses are too high in that part. You can see the hard place in the additional reinforcements on the raft foundation. you can save the foundation with less additional reinforcement area by placing a column by distributing the stress.The most reliable solution is to extend the P19 curtain up to the S06 column if it will not pose an architectural problem.
Thank you very much for your attention. It gave results. 24 fi 5 in some regions, but it saved some places. I wonder if there is a mistake in design. Good work, good luck
