Raft Basic Reinforcement Insufficient Error
your problem is reinforced concrete design in raft slab additional reinforcements.....parameters.....parameters of raft slab.....the minimum additional reinforcement spacing is (10 cm) you do eight (8 cm) repeat the analysis and the additional reinforcement fi 16 /8 cm apart OR reinforced concrete design.....reinforcement selection.....flooring-raft flooring.....you marked raft flooring additional fi 14 and 16 at fi 18 ide (reinforcement fi 18 / 10 cm) intermittent beats saves)
Hello. (additional reinforcement saves fi26) Check fi26 --No flexible joint or connection Select 4.9.1.3 --Remove fixing ticks on the raft slab, error-free results are obtained.
hello, if the number of mods is insufficient, increasing the number of mods is 54 , 75 or whether it is a bit exaggerated, does the growth of values like 125 1-does it indicate a problem with the design 2-what are the main reasons for the enlargement of these numbers 3-as far as I remember, 18 on ide 7 is 54 what is the reason for this change
Which should be increased in case of insufficient number of mods In which case should the numbers 1 and 2 be increased 1-modal E1,E2,E3,E4 should be increased or 2-modal BE1,BE2,BE3,BE4 should be increased
"asenyapitasarim":eztxdm58" said:
in case of insufficient number of mods which should be increased In which case should the numbers 1 and 2 be increased 1-modal E1,E2,E3,E4 should be increased 2-modal BE1,BE2,BE3,BE4 should be increased
