Hello, I opened your project, I analyzed without touching anything. Your maximum torque value appears to be -269 tm from the vertical load. If the raft thickness is 110 cm, the missing Ace disappears. Of course, to meet the 269 tm moment, more additional reinforcement is required compared to other regions... If necessary, you can try to make the raft thickness 120/130 cm. If the ground tension exceeds, you can increase the floor area a little more. Good work...
