Radye I solved in ideCAD 7 did not save in 8
furkizbey
Hello, when I transferred the project that I solved in idecad 7 to idecad 8, the problem appeared on the raft. I'll be happy if you can help me. Regards Furkan Özbey Link:
Re: The raft I solved in İdecad 7 did not save in 8 Hello Furkan Bey, We examined your project in 8 versions. The lack of reinforcement in the raft foundation is due to additional reinforcements. If larger rebar diameters are selected and the minimum spacing of additional rebars is reduced, the problem is solved. If you add the project data of version 7 or send it to [email protected], we can examine the reason for the change. Notes: - It would be appropriate to model the basement perimeter curtains as shells in the project. -Review the slabs with incorrect levels in the message given in the geometry control. -The gaps opened on ribbed and cassette flooring teeth are not taken into account. -Single console rib and cassette flooring with no continuity is not designed. Good work
