General Conditions for the Ductility Levels of Structural Systems in section 2.5.1 of the Earthquake Code and R from the Table of Structural System Behavior Coefficient (R) in Table 2.5 on Page 13 You can get information about the coefficient."fuatturan":28osfmox" said:where do we look at the R coefficient calculated by the program
At the beginning, you give the R coefficient according to the structure type and ductility level to the program in the "Analysis Settings". (Follow NYILMAZ's message) If, after the analysis, B1 irregularity occurs in your structure, the R coefficient is automatically reduced by the program by multiplying by 1.25cmmin. You do not need to take any action on this. If your structure is curtained system and mixed and/or high ductility, R you need to arrange the coefficient according to the alphas ratio... For this, the program warns you during the report. Then, in the "Earthquake Regulation General" report, you need to re-enter the R coefficient suggested under the heading "Reason for Choosing the R coefficient" into the program and repeat the analysis. The (calculated) R coefficients are b under the heading "Reason for Choosing R coefficient" in the "Earthquake Regulation General" report. will hang. Good work"fuatturan":2qwwxfm2" said:thanks, but I say the coefficient calculated by the program
