We are getting such an error in our project. What could be the solution method?
Log in or register now.
"zekaikc":1lv55un6" said:We get such an error in our project. What could be the solution method? [/quote ] Hello, In your project, the ends of TK64, Tk65,TK21, TK22, TK812, TK813 continuous foundations appear to be free. The continuous foundations defined as free-end can be seen from the report. Fix the connections of these foundations. Since you are making a solution together with the structure-foundation, the unsupported continuous foundations affect the vertical loads of the column, some It works upwards in vertical loading on the columns, which causes the total (Nk) value to be negative. After correcting the continuous foundation connections, make the width of the foundations on 1 axis 100 cm instead of 80. There will be no problem. In addition, in your structure, 5 rigid diaphragms (structure ) and rigid basement walls are partially present at some edges, in some rigid diaphragms (structures). has. 1 and 2 have only the upper edges. In the analysis settings, you have accepted that there is a rigid floor in the x direction, you have accepted that there is no rigid floor in the y direction. The rigid floor definition in the analysis settings will be valid for the whole project. However, for 5 rigid diaphragms, 5 different rigid floors must be assumed. Therefore, either enter the rigid diaphragms as separate projects or do not define rigid floors as they are partial curtains (give -2 in the x and y directions). In the attached project, the problem of "total Nd in X,Y direction is greater than 0.45* total Nk" has been fixed. Works done: 1. Connections of continuous foundations with free ends were fixed. 2. Continuous foundations on axis 1 are defined as 100 cm wide instead of 80. 3. The rigid basement floor number is given as -2 in the x and y directions.You do not have permission to view link Log in or register now.
