"There is another object in the same coordinates" on the basement floor curtain
cankara
Hello, I get the warning "There is another object in the same coordinates" at the junction of 2 basement floor curtains and 1 stair curtain on the basement floor, and I cannot analyze because I get the warning that the system cannot be resolved. How can these curtains be combined? I request your help in this matter. Thanks.
Re: "Another object in the same coordinates and İdecad file is attached on the basement floor curtain.
Re: There is another object in the basement floor curtain with ''same coordinates v
"cankara":tbsgx1wx" said:
Hello, There is another object in the same coordinates at the junction of 2 basement floor curtains and 1 stair curtain on the basement floor "I am getting the warning "and the system cannot be resolved, so I cannot analyze. How can these curtains be combined? I would like your help in this regard. Thank you.
Hello, The problem of the system cannot be resolved is caused by the ladder. The ladder arms are not connected to each other. Creation and support of the stairs from the links below Creating the ladder
Determination of stair support conditions
-P01 curtain beam connections are faulty. The connected beams must be connected from the inner node of the curtain. In addition, the nodal points of the beams connected to the curtain in the y direction are not on the curtain. There is no need to enter beams on basement curtains. Curtains can be defined along the floor height and floor edges can be curtains. -The values entered in DD-3 in the TBDY Wizard/Design Spectrum tab are incorrect. The coefficients given for the DD-3 earthquake ground motion level must be entered from the Earthquake Map. Good work
