eissenhover
QUESTION-1) HOW CAN I CALCULATE THE WEIGHT TYPE (STONE) WALL ACCOUNT? QUESTION-2) Architectural sections are available in the add-on I uploaded, excluding the thickness of the foundation. The bottom of this channel will remain 120 cm below the 0 level, that is, the soil force will act on the side walls of the channel. I think that if I analyze this channel in idecad as basic + 2 side screens, I think I will get out of it. What do you think, would such an analysis be correct for the channel principle? Also, I think it is not possible for me to give the inclined (chamfered) area at the base in idecad. I will define a lateral load on the side bulkheads that will be subjected to ground forces. I will create and effect lateral load combinations as I learned from the idecad forum. besides, what will be the value of the curtain? How many tf/m2 value would be correct. nFor example, 1 tf/m2, if I put a one-ton force on m2, would it be too much or less? Question-3) When defining lateral load for curtains, I define two combinations, 1.4g+1.6q+1.6H and 0.9g+1.6H, as explained in the forum, and select the relevant curtain and add horizontal load. I select the H line from below and enter the value of the load. When I examine the screen analysis report, only one of the two combinations that I have defined appears. why don't two of them come out. WHEN I CHOSE LINE H BELOW, CAN'T THE PROGRAM ASSUME ALL THE COMBINATIONS WITH H? OR I SHOULD SAY H1 AND H2 FOR THE TWO COMBINATIONS AND ADD HORIZONTAL LOAD, ADD BI H1 AND THEN ADD ADDITIONAL HORIZONTAL LOAD AND ADD H2 TOGETHER, I DID NOT UNDERSTAND, CORRECT?
