Question About Getting Building Symmetry
bha
Greetings, there are buildings that are symmetrical to each other in my hand, there is no problem when I enter the a block from scratch, but when I get the symmetry of the building, a dc error occurred in the D10 flooring on the ground 1-2-3 floors 1-Is it correct to solve by taking symmetry in Ide statics 2-If it is true, what could I have done wrong in the modeling files are attached. . Thank you.
Hello, 1-The solution can be made by taking symmetry in the program. 2- In the main project.cde file, the right slab edge of the D02 slab on the ground and normal floors is not connected to the S2 column. Therefore, the slab is not formed correctly and the slab analysis is done incorrectly. When this problem is fixed in the main project and the project whose symmetry is taken, the problem with the tiling is solved. Good work
