Quantity According to Rebar Diameter
mehmetba
Hello, I want to take the quantities separately according to the iron diameters while taking the quantities of the project I made with idecad. You can see the beam quantities in the picture, it doesn't matter what beam or column I want, we have to buy 14-gauge irons as a single group, 12-gauge irons as a single group, we have to create a metering sheet for grant projects, we have to copy and paste these quantities from pdf one by one, it is both very tiring and it takes a lot of time.
Hello, In the dialog below, when you mark Quantity according to the elements or according to the floor and take the quantity, the grand total is given according to the diameter as you want.
Thank you for the answer, this is not exactly what I want; Again, let's give it separately for each element, if we take the image I added as an example, all of the KRZ01 Assembly, KRZ02 Assembly KRZ02 Additional and KRZ01 Additional reinforcements should be given in a single group like this, and the element names should be included. KRZ02 Straight and KRZ01 Straight reinforcements should be given as a separate group together with 14's. As you know, irons with a diameter of 14 and above are considered thick and their exposure number is different. In summary, when taking quantities, I want to buy thin irons in the form of 8-10-12 in a separate order, including column beam and reinforcement names (stirrup, additional, flat, etc.), and thick irons in the same way.
