insburak355
Hello everyone, I have curtains in the elevator stairwell section, which we call core in my project, I solved a project b+z+7. My 1st problem was that I had 25/60 beams connected perpendicular to the plane of the curtain ()K46-K58) it was giving a shear error, I opened it to examine it and saw an incredible pile of reinforcement. 4fi14 mounted 8fi18 reinforcement on the mounting supports, but it did not give a pursanta error, I would be happy if there is a friend who can explain it? yes, it is possible for it to fit on a 25 cm wide beam, but there is no way for concrete aggregate to enter between it. My second problem is that I turned these 25/60 beams into 55/32 hollow blocks (the building was already hollow, I was passing only the core with pendent beams), I don't know if it's because it's a short beam again. There is too much reinforcement. Should I manually reduce the stiffness of these beams? If I do, can there be a decrease in the equipment? How much should I do the stiffness reduction 0.7? 0.5? short beams are always a problem. In general, if you have any suggestions, I would be glad (except for making short beams, remove beams
) Also, what exactly does stiffness reduction mean in application and static project calculations? I would be very happy if you have any suggestions or suggestions.
