PUNCHING SAFETY AND RATH FLOOR FLOOR SAFETY PROBLEM
mühendis12
Hello, after analyzing the project I prepared, it gives an error in stapling security in 2 columns. I increase the column sizes, but I still encounter the same problem. Also, I am facing floor safety problem in raft flooring. Even though I increase the apartment, the problem is not solved, how can I follow a path. It gives a floor thickness error on the balconies. I increase the floor thickness and this time the reinforcement is insufficient. No matter how much I increase the amount of floor reinforcement, after the analysis, I get the result of insufficient reinforcement. I will be glad if you help.
