onurceylan
Hello, I have an L-shaped A Block project. I also have a B Block project that is symmetrical with respect to the Y axis. The static project of Block A is finished. How can B Block, which is symmetrical, be solved in the shortest way? Is it possible to get the symmetry, if possible, can you explain in detail how to do it? I hope there is a short way, the static project of Block B, which is symmetry, does not need to be solved again. Good luck with...
